03-20-2008 09:06 PM
Hi all,
I'm using AS5350XM for prepaid calling card and termination. I was calling to my special number (prefix 1672) then I got busy signal.
What is the problem?
Please see the configuration from the enclosed file 'config_file.txt'.
03-21-2008 05:52 AM
If you enable "debug voip dialpeer", do you see the call hitting the proper dial peer? How about on the remote gateway - 206.x.x.x?
Brandon
03-23-2008 06:57 PM
Hi Brandon,
I imagine that If I call to our special number, first I should hear IVR like "Welcome to cisco demo version"
second after that I enter the account number and pin.
third Then if it has enough money then i can collect number.
but first process wasn't happen. I hear busy signal.
Sorry for my English.
03-24-2008 07:17 AM
Did you enable the debugs as suggested in my previous post? If you telnet to the router, do the following:
router#term mon
router#debug voip dialpeer
After entering the commands above, make the call and look at the outpout to see if it is hitting the correct dial peers.
Brandon
03-24-2008 08:03 PM
Hi Brandon,
router#sh debugging
DIALPEER:
debug voip dialpeer error call is ON (filter is OFF)
debug voip dialpeer error software is ON
debug voip dialpeer inout is ON (filter is OFF)
When I was calling from my mobile phone 99083297 to our special number 1672 I hear busy signal.
Calling Number=99083297, Called Number=1672, Voice-Interface=0x0,
Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
Peer Info Type=DIALPEER_INFO_SPEECH
*Mar 25 02:48:38.079: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=1672
*Mar 25 02:48:58.763: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
