Choice of multiple default gateway
Answered Question
Mar 21st, 2008
  • Silver, 250 points or more
If I have two default route (D1 and D2) with two subnet connected (S1 and S2), is there a way to forward traffic through D1 or D2 with reference to the sender IP, that is network hosts belonging to S1 have default route D1 and hosts belonging to S2 have default route D2?.
Thank you.
Best regards.
Massimiliano.
Correct Answer by Jon Marshall about 9 years 2 months ago
Hi Massimiliano
You can use PBR (Policy Based Routing) to achieve this.
S1 = 192.168.5.0/24
S2 = 192.168.6.0/24
access-list 101 permit ip 192.168.5.0 0.0.0.255 any
access-list 102 permit ip 192.168.6.0 0.0.0.255 any
route-map DEFR permit 10
match ip address 101
set ip next-hop
route-map DEFR permit 20
match ip address 102
set ip next-hop
Then you apply the policy onto the relative interface ie.
int fa0/0
ip polict route-map DEFR
Jon
Overall Rating: 4.5 (2 ratings)
Correct Answer
Jon Marshall Fri, 03/21/2008 - 02:21
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Hi Massimiliano
S1 = 192.168.5.0/24
S2 = 192.168.6.0/24
set ip next-hop
set ip next-hop
int fa0/0
Jon
massimiliano.se... Fri, 03/21/2008 - 03:18
Hi Jon,
Thank you.
Can I use PBR on switches Layer 3 also?
Can I apply route map to interface VLAN?
Best regards.
Massimiliano.
Richard Burts Fri, 03/21/2008 - 03:54
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Massimiliano
Yes you should be able to use PBR on most layer 3 switches. Note that you may need to adjust the SDM template (to use the routing template) on some of the switches to get support for PBR.
Rick
