CUE Editor with CUE on UC520
Mar 21st, 2008
Hi All ^_^,
CUE Editor Ver. 2.3.4
CUE on UC520 Ver. 2.3.4
I try to modify/create an AA script. Every time i want to test it, I got an RMI error (RMI OP can not accept calls made in RMI protocol 1.1...). There is somebody who had the same problem? On the Cisco website I can not find any docs regarding this error.
I attach the screenshot of the error.
Tnx so much.
Marck
Anonymous (not verified) Thu, 04/10/2008 - 18:02
marckalex Sun, 05/04/2008 - 00:03
Re:
Post upgrade of UC500 with CUE 3.0.3, CUE Editor not work.
CSCsk29868 Bug Details
Reactive Debugging on CUE editor does not work in J9
Symptom:
Reactive debugging in the CUE Editor does not work with UC500. The error message we get is "RMI OP can not accept calls made in RMI Protocol 1.1 for class com.cisco.wfframework.engine.rmi.RemoteWorkflowEngineImpl."
Conditions:
Use the reactive debugging feature in UC500
Workaround:
None
By Marck
