03-21-2008 02:25 AM - edited 03-10-2019 03:44 PM
Have anyone encountered this problem before? My radius is at 192.168.1.10 and R1 is on 192.168.1.1. Both are connected to a switch and ping works perfect. ACS has been configured with R1 as the AAA client with a key. I'm baffled as to why this does not work. I've even changed the authentication to TACACS+ and still the same problem occurs.
R1#test aaa group radius cisco cisco legacy
Attempting authentication test to server-group radius using radius
No authoritative response from any server.
R1#ping 192.168.1.10
Sending 5, 100-byte ICMP Echos to 192.168.1.10, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
03-21-2008 02:32 AM
debug radius authentication shows
*Mar 21 09:31:26.919: RADIUS: User-Name [1] 7 "cisco"
*Mar 21 09:31:26.919: RADIUS: User-Password [2] 18 *
*Mar 21 09:31:31.687: RADIUS: Retransmit to (192.168.1.10:1645,1646) for id 1645/
*Mar 21 09:31:36.327: RADIUS: Retransmit to (192.168.1.10:1645,1646) for id 1645/
*Mar 21 09:31:41.095: RADIUS: Retransmit to (192.168.1.10:1645,1646) for id 1645/
4No authoritative response from any server.
Rack01R1#
*Mar 21 09:31:45.799: %RADIUS-4-RADIUS_DEAD: RADIUS server 192.168.1.10:1645,1646
is not responding.
*Mar 21 09:31:45.799: RADIUS: Tried all servers.
*Mar 21 09:31:45.799: RADIUS: No valid server found. Trying any viable server
*Mar 21 09:31:45.799: RADIUS: No response from (192.168.1.10:1645,1646) for id 16
45/4
*Mar 21 09:31:45.799: RADIUS: No response from server
Rack01R1#
*Mar 21 09:31:45.803: %RADIUS-4-RADIUS_ALIVE: RADIUS server 192.168.1.10:1645,164
6 is being marked alive.
Tried changing the ports to 1812,1813 still the same. No Windows FW turned on in the ACS Server..
03-21-2008 08:43 AM
Latest update. Managed to solve the problem..
Resolution: Re-install Cisco ACS
But would definately welcome a better suggestion than the above for anyone who has experienced this problem before. Could it be Java related problem?
