DHCP Configuration
Mar 21st, 2008
I have a 3750G-E switch. When I tried configuring a DHCP server within the switch, it was not giving out ip addresses on all the ports. So, I tried configuring the ports to use VLAN 1, and it is now working.
My question is that, is there any way that I can create multiple DHCP server in a 3750G switch to cater to multiple VLANs (vlan 10, 20, 30, etc) other than vlan 1.
Ninoy
Richard Burts Fri, 03/21/2008 - 03:51
Ninoy
Yes you can create multiple DHCP ranges that correspond to multiple VLANs. You would create multiple DHCP address pools with subnets that correspond to the subnet addresses of the VLAN interfaces. Then when a DHCP request is received the switch looks at the VLAN interface it was received on and assigns an address from the pool that corresponds to that subnet.
Rick
optionstechnology Thu, 04/17/2008 - 01:11
should this work for voice vlan's ?
i don't seem to be getting a voice vlan dhcp address from the switch
ie
ip dhcp pool client-pc
network 192.168.250.0 255.255.255.0
ip dhcp pool client-voip
network 192.168.251.0 255.255.255.0
interface Vlan250
ip address 192.168.250.1 255.255.255.0
interface Vlan251
ip address 192.168.251.1 255.255.255.0
interface GigabitEthernet1/0/2
switchport access vlan 250
switchport mode access
description IP Phone Port
switchport access vlan 999
switchport voice vlan 251
Can you help ?
thanks
-Paul
mahmoodmkl Thu, 04/17/2008 - 01:19
U havent specified the default-router option for u r address ranges configure it and check.
Mahmood
optionstechnology Thu, 04/17/2008 - 01:36
i've just snipped off some of config for clarity
the complet voice dhcp scope config is...
ip dhcp pool client-phone
dns-server 192.168.5.200 192.168.7.203
netbios-node-type h-node
domain-name xxx.com
default-router 192.168.251.1
option 150 instance 1 ip 192.168.200.10
option 150 instance 2 ip 192.168.210.10
option 66 ascii "phone"
lease infinite
