glbp configuration
Mar 21st, 2008
scenario;
-2x6500 with fwsm on each
-msfc with user vlans 12,13 running glbp
-no trunk connections between the 2x6500
-user edge switch having trunk connections to both of the core
CORE CONFIG
CORE 1
int vlan 101
ip address 192.168.101.1 255.255.255.0
glbp 101 ip 192.168.101.254
glbp 101 priority 110
CORE 2
int vlan 101
ip address 192.168.101.2 255.255.255.0
glbp 101 priority 105
QUESTION;
-why if i removed 1 one of the uplink on the edge, my connection get lost and will never come back.
jaye15394 Fri, 03/21/2008 - 07:36
You say you have glbp running on vlans 12,13. Where is that configuration?
The config is only showing GLBP for VLAN 101 on the core.
Jason
