ASA ESP issue
Mar 21st, 2008
We have a new ASA, there are no firewall rules associated to the inside interface. Our finance department has to run the AT&T net client to connect with Medicare, this now fails. On the ASA I get an error that says 3|Mar 20 2008|10:41:39|305006|12.64.175.2||regular translation creation failed for protocol 50 src inside:10.0.50.30 dst outside:12.64.175.2
NAT-T is on the firewall and I also tried the inspect ipsec pass through to no avail. Any other suggestions?
abinjola Fri, 03/21/2008 - 08:02
  • Cisco Employee,
on the remote VPN server either enable NAT-T or on create a 1-1 static on the firewall opening ESP and UDP-500 on the firewall
boshardy1 Fri, 03/21/2008 - 08:53
I don't have control of the remote end, it's medicare. Is there anything else I can do on my end to make this work short of doing static NAT's? It used to work on my netscreen firewall somehow only since switching to the ASA has it broke.
JORGE RODRIGUEZ Fri, 03/21/2008 - 09:47
  • Green, 3000 points or more
In your VPN client,ATT connection properties, transport tab, where you have checked off if you do Enable Transparent Tunneling choose Ipsec over UDP (NAT/PAT).
abinjola Fri, 03/21/2008 - 10:06
  • Cisco Employee,
Jorge..this would still not work..by default enable transparent tunneling is enabled..here the problem is since the remote server doesn't want to enable NAT-TRansparency therefore the ESP packet would never be encapsulated over udp 4500 and there ESP would not be able to PAT...
only way to get this working is 1-1 static or NAT traversal
JORGE RODRIGUEZ Fri, 03/21/2008 - 10:33
completely agree, you are right.. wander what happened to my cup of coffey..
cisco24x7 Fri, 03/21/2008 - 12:50
  • Silver, 250 points or more
One of the things to keep in mind when switching from one firewall vendor, Juniper,
to another firewall vendor, Cisco, is that
different device can handle things
differently. Devices such as juniper or
netscreen has the ability to do "IPSec
pass-through" that devices such as Pix or
ASA can NOT.
That being said, if you replace the ASA
with a Cisco IOS router with the ability
to do this:
ip nat inside source static udp 192.168.1.1 500 interface F0/0 500
ip nat inside source static esp 192.168.1.1 interface F0/0
where 192.168.1.1 is the host beind the router.
That will enable the client to connect via
ESP.
It is very unfortunate that ASA can not do
this.
CCIE Security
abinjola Fri, 03/21/2008 - 13:14
  • Cisco Employee,
"IPSec pass-through" that devices such as Pix or
ASA can NOT.
ASA can do IPSEC pass through but you cannot port address translate an ESP packet, thats the reason NAT-Transparency came in picture which means if VPN server has it enabled it detects the client to be behind PAT device and the clients starts encapsulating ESP over UDP which can PATTED now...
hope it answers !
cisco24x7 Fri, 03/21/2008 - 13:17
what I meant to say is:
Can ASA do this?
jan.nielsen Sat, 03/22/2008 - 18:34
  • Gold, 750 points or more
Oh, and also, run 7.2 software, i think i remember something about some bugs with the ipsec inspect before this release.
