PXE boot through FWSM
kschuerman
I am attempting to setup a windows deployment server to work through our FWSM. The workstation and DHCP servers are on different vlans on the outside interface of the FWSM. The WDS is a separate vlan on a different FWSM interface. The workstation is getting an IP and I verified that it is receiving option 66 and 67 using wireshark.
The client will get an IP address at boot, but I receive a TFTP open timeout error. I do not see any deny messages in the FWSM log viewer. I do have an ACL allowing TFTP to the WDS from any.
Does the WDS server need to be listed as a DHCP relay server in the FWSM config?
Any other possible solutions?
Thanks.
kschuerman
I just realized this went into the wrong category, is there anyway to move it?
