E1 PRI and codecs
Mar 21st, 2008
Hi Guys
here is my diagram
PBX--E1---Router1---E1---Router2--E1-PBX
I set codec G729 for pbx calls to user more bandwidth.
so should I do any configuration for passing this coded between R1 and R2?
or the router r1 acts with them as data?
1lumkk Fri, 03/21/2008 - 08:52
You can set G729 as the preference on the dialpeer. For example.
dial-peer voice 11 voip
description #To R1#
destination-pattern 1....
session target ipv4:1.2.8.8
dtmf-relay h245-alphanumeric
codec g729ulaw
