Translation in CCM
Mar 21st, 2008
I planning to have 10 digit extensions in CUCM I want the users to be able to dial both 10 digit or just last 4 digits of their numbers to call each other? How can this be done, since all the translation rules refer to external calling and not internal extension to extension ?
Overall Rating: 5 (1 ratings)
Brandon Buffin Fri, 03/21/2008 - 10:49
You can create a translation pattern to accomplish this. Make the translation pattern 111222XXXX for example and make the called party transform mask XXXX. Make sure the translation pattern is in a partition accessible by the CSS on the internal phones.
Hope this helps. If so, please rate the post.
