PXE boot through FWSM
Mar 21st, 2008
I am attempting to setup a windows deployment server to work through our FWSM. The workstation and DHCP servers are on different vlans on the outside interface of the FWSM. The WDS is a separate vlan on a different FWSM interface. The workstation is getting an IP and I verified that it is receiving option 66 and 67 using wireshark.
The client will get an IP address at boot, but I receive a TFTP open timeout error. I do not see any deny messages in the FWSM log viewer. I do have an ACL allowing TFTP to the WDS from any.
Does the WDS server need to be listed as a DHCP relay server in the FWSM config?
Any other possible solutions?
Thanks.
tstanik Thu, 03/27/2008 - 12:16
You need to enable dhcp relay on FWSM. In order to enable DHCP relay on the interface connected to the clients, enter these commands:
dhcprelay enable Outside
dhcprelay server ip_address Outside
