Axl Sql
Mar 21st, 2008
I'm trying to use the axlsql toolkit to add Directory numbers to the Communications manager ver 6.0. Does anyone know how that would be done? Any insights on Axl Sql or just Axl would be appreciated.
Tim Smith Wed, 03/26/2008 - 05:19
  • Silver, 250 points or more
Hi Wesley,
This would require some programming.
I started experimenting with AXL a while back.
I found it relatively easy to accomplish simple tasks like this by writing programs in Microsoft Visual Basic .NET.
In essence AXL is an API in the form of a web service. You have to write a program that generates the appropriate SOAP message and sends it to the CallManager server over HTTPS.
At the end of the day you can use any language / method you want, as long as a SOAP message arrives at the CallManager in the correct format, and with the required parameters.
Not sure if that helps at all.
Cheers,
Tim
