cat-4506 remove vlan info
Mar 21st, 2008
I'm currenty upgrading a cat4506 switch
and I'm trying to remove the old vlan files. The delete command but it's still there. Basically, I'm upgrading the sup mod from a production switch with a spare. I was able to get the IOS and config over via removeable flash.
However, the spare sup was a used moduled and it has old config.
can anyone please assist if they know how? thx
NJ02GA03F3S01#delete /force cat4000_flash:vlan.dat
Delete filename [vlan.dat]?
IOS (tm) Catalyst 4000 L3 Switch Software (cat4000-I9S-M), Version 12.1(19)EW1,
TAC Support:
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Mon 28-Jul-03 16:10 by eaarmas
Image text-base: 0x00000000, data-base: 0x00F12E30
ROM: 12.1(20r)EW1
Dagobah Revision 55, Swamp Revision 16
NJ02GA03F3S01 uptime is 13 minutes
System returned to ROM by reload
System image file is "bootflash:"
cisco WS-C4506 (MPC8245) processor (revision 7) with 262144K bytes of memory.
Processor board ID FOX07041PWV
Last reset from Reload
2 Gigabit Ethernet/IEEE 802.3 interface(s)
467K bytes of non-volatile configuration memory.
Configuration register is 0x2101
Overall Rating: 5 (1 ratings)
glen.grant Fri, 03/21/2008 - 14:07
Change the vtp mode to transparent then do a write erase on the switch and reload the box and it should wipe out those vlans.
