CSS 11501 100% CPU
Mar 21st, 2008
I have a CSS running at 100% CPU with no services up. I cannot ping the CSS interfaces after about 1 minute of up time. Im running 8.1. Any ideas? I turned logging back to default and turned off my ACLs.
Gilles Dufour Mon, 03/24/2008 - 04:11
  • Cisco Employee,
you'll need to go in llama/debug mode and do the following
symbol-table load SPRITZ
shell 1 1 spy
shell 1 1 spyStart
shell 1 1 spyReport
shell 1 1 spyReport
shell 1 1 spyStop
symbol-table unload
Do this when the CPU is high.
This will tell us the cause.
Also, if you only see the problem when logging is set to debug, then I would say do not set the level of logging so high unless you are trying to debug an issue.
Gilles.
