Unity Connection 2.X
Mar 21st, 2008
I'm trying to figure out a way to get the voice mail messaes that are sent to my IMAP mailbox forwarded to my smartphone so that I can be notified of voice messages. Has anyone had success in doing this? I created a rule that forwards the voice messages from the IMAP inbox to my exchange inbox but that only works when the outlook client is open and is able to download the messages. I would like to be able to get these voice messages regardless of whether outlook is open or not.
okuehn Sat, 03/22/2008 - 03:14
  • Bronze, 100 points or more
within unity connection you are not able to foward voice messages (wave files) to email adresses. you can only use imap client to pull your CUC imap inbox.
however, you can setup a email notification in CUC. with this, you will be informed by mail that you have received a voicemail. then you can use your smartphone to dial in an check your voice messages by phone.
hope this helps!
