Cannot route to Internet
Mar 21st, 2008
I havew three 2960 switches with multiple VLANS setup. I have them stacked together using the Gige uplink ports and config using Network Assistant.
My Internet router is on VLAN 1 port 48
I cannot access it from any other VLAN other than VLAN1.
Below is a snapshot of my config.
cluster enable RBC_Stack 0
cluster member 1 mac-address 001f.2606.3d80
cluster member 2 mac-address 001f.264a.f380
no file verify auto
spanning-tree mode pvst
spanning-tree uplinkfast
vlan internal allocation policy ascending
interface FastEthernet0/1
switchport access vlan 5
switchport mode access
spanning-tree portfast trunk
interface FastEthernet0/44
switchport access vlan 7
interface FastEthernet0/45
interface FastEthernet0/46
interface FastEthernet0/47
interface FastEthernet0/48
interface GigabitEthernet0/1
switchport mode trunk
interface GigabitEthernet0/2
interface Vlan1
ip address 172.17.1.10 255.255.255.0
no ip route-cache
interface Vlan5
ip address 172.17.5.1 255.255.255.0
ip helper-address 172.17.5.5
no ip route-cache
interface Vlan7
ip address 172.17.7.1 255.255.255.0
no ip route-cache
interface Vlan10
ip address 172.17.10.1 255.255.255.0
no ip route-cache
ip default-gateway 172.17.1.1
Edison Ortiz Fri, 03/21/2008 - 15:03
  • Hall of Fame,
    Founding Member
Not sure how you were able to configure more than one Layer3 interface on a 2960 switch.
A 2960 switch is strictly Layer2 and only one Layer3 interface can be enabled at the same time and this interface is used only for management, not for inter-vlan routing.
The connection from the switch to the router must be configured as a trunk interface and you need to configure all the Vlans you have above in the router. The router will perform the inter-vlan routing.
HTH,
__
Edison.
dagoose66 Fri, 03/21/2008 - 16:21
The router is a PC with 2 NICS running Linux.
Am I missing something?
Thx
Edison Ortiz Fri, 03/21/2008 - 18:01
  • Hall of Fame,
    Founding Member
You are missing a device that is able to perform the inter-vlan routing on the Vlans you've created.
I'm not very familiar with Linux networking but in addition to the Linux kernel, the NIC must support dot1q trunking. You need the Linux box to perform inter-vlan routing for all the subnets as the switch you've purchased can't do it.
Just to verify you are indeed running a 2960 switch, can you post the output while typing the following commands in the switch:
show ip interface brief | ex una
and
show version
dagoose66 Sat, 03/22/2008 - 08:29
Thanks for the help.
they are 2960's, I have the wrong switches for what i need to do.
Richard Burts Sat, 03/22/2008 - 08:39
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Donald
There is another issue evident on your config which causes the inability to route to the Internet. Your "router" is on port 48 which is configured as an access port. So only devices in VLAN 1 can access it. The typical solution for inter VLAN routing is to make the connection to the router to be a trunk port so that all the VLANs can be carried over the trunk. This allows devices on all the VLANs to access the router and allows the router to provide inter VLAN routing. The 2960s are not necessarily the wrong switch - many people successfully implement inter VLAN routing on 2960s. But they need to have some device that can trunk and do layer 3 inter VLAN routing.
Rick
Richard Burts Sat, 03/22/2008 - 10:06
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Brandon
If they are 2960 switches then turning on IP routing is not an option. The 2960 is a layer 2 switch and does not support routing.
[edit] though as Edison points out the configuration of VLAN interfacess 1, 5, 7, and 10 with IP addresses suggests that this might not really be a 2960. And in that case your suggestion about turning on IP routing is quite right.
Rick
