Problem Switch with Vlan
Mar 21st, 2008
Dear Expert,
Now i have problem with Core switch 4506 and switch 2960. my problem is, when i connected switch 4506 and 2950 and i create Vlan 2 until 10, by the way when i show run i see all vlan in interface but when i show vlan i don't see Vlan 8 and 9 .Could you tell me what's going on?
and i show vtp status on CoreSwitch i see
VTP Operating Mode : Transparent
and i show Vtp status on Switch 2950 i see, VTP Operating Mode : Client
what happen on both switch?
Pleas help me !!!!!!
Best Regards,
Join
Kevin Dorrell Fri, 03/21/2008 - 19:37
  • Green, 3000 points or more
Where did you create the VLANs? The 2950 is VTP client, so it will only learn the VLANs from a VTP server, if you have one. The 4506 is VTP transparent, so it will not learn VLANs at all - you have to configure them manually, and even then it will not update any other switch.
I guess you created the VLANs in the 4506. In that case, make the 2960 VTP transparent, and add the VLANs manually there as well.
Kevin Dorrell
Luxembourg
Rick Morris Tue, 03/25/2008 - 09:07
  • Silver, 250 points or more
Set your core switch up as vtp mode server and all access switches as vtp mode client
build the vlan's in the switch and you will see all vlan's propigated to the clients in the same domain.
This way you will not have to build seperate vlan databases on each and every switch in your enviroment.
