Need LAB Practice
Answered Question
Mar 21st, 2008
Hello, folks:
I would like to ask if anyone can recommend a really good network lab simulator.
The problem is that I need more hands-on experience. I have plenty of theoretical knowledge and a solid understanding of routing and switching. I have done a lot of operations work, which has helped broaden my fund of knowledge.
These day, however, I would like more PRACTICAL experience actually configuring different technologies in different scenarios and with certain requirements.
Does anyone know or used a really good product? I want something that is really intricate and can really allow someone to grow and learn.
Michael
Correct Answer by CSCO10892433 about 9 years 5 days ago
Hi, Michael
There is a good simulator called dynamips that might suit your need.
http://www.ipflow.utc.fr/index.php/Cisco_7200_Simulator
You need a powerful PC to run this program, and you also need a real ios image to make it work.
SSLIN
Overall Rating: 5 (1 ratings)
