Need Recommendation for LAB Practice
Answered Question
Mar 21st, 2008
Hello, folks:
I would like to ask if anyone can recommend a really good network lab simulator.
The problem is that I need more hands-on experience. I have plenty of theoretical knowledge and a solid understanding of routing and switching. I have done a lot of operations work, which has helped broaden my fund of knowledge.
These day, however, I would like more PRACTICAL experience actually configuring different technologies in different scenarios and with certain requirements.
Does anyone know or used a really good product? I want something that is really intricate and can really allow someone to grow and learn.
I dont want CCNA stuff. That is way too easy for me. I can configure interfaces and basic routing and switching in my sleep.
I need a CCNP/CCIE level product where I can fool around with BGP and configure it to support multiple Internet access points, duplicate data centers, etc; PIM; load balancing; firewalls; etc.
Michael
Correct Answer by mattcalderon about 8 years 11 months ago
Then I would recommend the ipexperts especially if you are looking for something more at your pace. Ipexpert gives the lab books and the example topologies for you to follow. good luck with your studies.
Overall Rating: 5 (1 ratings)
MW20082008 Fri, 03/21/2008 - 20:39
Hi:
Im not sure I understand. You directed me to another message board like this one...? Not quite sure what is special about that one...
MW20082008 Mon, 03/24/2008 - 13:02
Jorge:
I used your GNS link.
I downloaded the software Im having some trouble with it...Ill fix it soon.
More mportantly, thiugh, I think this is just something that simulates a lab environment...a virtual lab, so to speak. Thats cool, but I was looking for something that has lab exercises and practice, etc.
For example,
chapter 1, configuring IP PIM multicasting
chapter 2, configuring BGP in a multihomed environment
chapter 3 configuring OSPF stub routing to support a routed access layer
In other words, along with the virtual routers and switches that I can connect as I please, I want actual LABs that teach through a step by step approach.
Am I making sense?
mattcalderon Mon, 03/24/2008 - 15:30
Are you looking to pay for labs or more interested in getting some freebies? What you are talking about, if you want quality material does not come to you for free.
I have heard many rave reviews of http://www.ipexpert.com/.
Another one to look at is globalknowledge. I have taken many of their courses and they are great.
I also know that there are forums out there that will have the information above posted, but I don't necessarily condone that so I will not post any links. If you know how to use torrent then you will find what you are looking for.
MW20082008 Mon, 03/24/2008 - 15:58
Of course I am willing to pay...something reasonable for a product thats worth it, but, yes, willing to pay. I need something thats quality...
Anyone else?
Correct Answer
mattcalderon Mon, 03/24/2008 - 16:02
