FWSM UPGRADE FROM 2.3 TO 3.2
Mar 22nd, 2008
The FWSM 3.2 version is required to replace 2.3 version.
The version are using different commands and I wish to know how to do the translation between the current config-files (about 8 contexts plus 1 system context)and the target config-files supported by the new version.
Unless, there is an automotic update done during the installation?
Thanks for your help
François
JORGE RODRIGUEZ Sat, 03/22/2008 - 13:34
  • Green, 3000 points or more
Take a look at these two links, answers all of your questions.
Software release 3.2
http://www.cisco.com/en/US/docs/security/fwsm/fwsm32/release/notes/fwsmrn32.html
This link provides upgrading process details and requirements for both single and multiple context. Even though this pertains upgrading from 2.x to 3.1 based on the link above,the details presented in this applies to upgrading to 3.2 as well.
http://www.cisco.com/en/US/docs/security/fwsm/fwsm31/upgrade/guide/fwsm31up.html
Rgds
Jorge
