MPLS PE/CE configuration
Mar 22nd, 2008
I am tasked to make a local connectivity within one site. The interface vlan was associated to specific VRF. This Interface Vlan is being implemented with HSRP. From the router, i only got successful ping to HSRP gateway. Ping to host elements are not possible. Let me know your views also.
Edison Ortiz Sun, 03/23/2008 - 09:35
  • Hall of Fame,
    Founding Member
When pinging any of those addresses, you need to include the vrf option in the ping command.
Can you post your config?
Here is my config and it works:
ip vrf NETPRO
rd 1:100
interface FastEthernet0/0
ip vrf forwarding NETPRO
duplex auto
speed auto
standby ip 192.168.1.254
Rack1R1#sh ip route vrf NETPRO
Routing Table: NETPRO
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
C 192.168.1.0/24 is directly connected, FastEthernet0/0
Rack1R1#ping vrf NETPRO 192.168.1.1
Sending 5, 100-byte ICMP Echos to 192.168.1.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 4/4/4 ms
Rack1R1#ping vrf NETPRO 192.168.1.254
Sending 5, 100-byte ICMP Echos to 192.168.1.254, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 4/5/8 ms
Rack1R1#
HTH,
__
Edison.
