GigabitEthernet ports on 7609 router
Mar 22nd, 2008
Here's the configuration:
interface GigabitEthernet1/23
description test
switchport
switchport access vlan 140
switchport mode access
switchport nonegotiate
speed 1000
duplex full
no cdp enable
spanning-tree portfast
The cable is straight and in good condition. I noticed when I inserted the cable to this port, the LED lid on that specific port turn to OFF. As checked the interface status, its down / down. I tried to shut and no shut but I got the same result.
Is there any way to check the integrity of that specific port? Thanks.
spremkumar Sun, 03/23/2008 - 23:17
hi
did u try checking up the logs ?
if not do check up when you are trying this.
That mite provide some clue on the possible reason behind this behavior.
regds
