CUE-Unity VPIM
Mar 22nd, 2008
has anyone done this integration before.
I would like to know how to test it.
i mean once the configuration is done, how can i make sure it is working.
Good day
Overall Rating: 5 (2 ratings)
Rob Huffman Sat, 03/22/2008 - 12:32
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Wissam,
Hope life is treating you well :) This section details quite nicely the steps involved with testing the config;
Verify
This section provides information you can use to confirm that your configuration is working properly.
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_configuration_example09186a00804dfe88.shtml#verify
Hope this helps!
Rob
twissam Sat, 03/22/2008 - 12:41
thanks a lot for your help, this what i needed exactly.
one thing is still missing, for this section:
Verifying Message Send VPIM Activity (from the doc u sent)
i donno how to send a message to another location, i am doing the test from cue, i am logging in and pressing 2, but does not give me an option to send to another location!!!!
Good day
youssef.ahmed Wed, 09/10/2008 - 01:53
I got that link before & did all integration steps.
BUT
from cue i got " remote voice mail system does not support this format"
from unity i do ont know where the voice mail gone
WHY??
dual_line Mon, 02/02/2009 - 04:24
Rob, yet again one of you're netpro posts has pulled me out of a very dark hole! 5 points!
Thankyou!!
