Can't ping internet from AIM-CUE
gabe
Hello, installed AIM-CUE with 2.3.4 into 2691 with CME.
- From the router's CLI I can ping CUE.
- From the CUE's CLI I can ping router and all of the local LAN.
- I can access the CUE's web GUI from the LAN without any problem.
- I CAN'T ping any internet IPs from the CUE, so NTP does not work.
I think I have been going around in circles for the last few hours, please help:
show run: (took out the obviously non related configs)
no aaa new-model
memory-size iomem 15
no ip source-route
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.168.30 192.168.168.255
ip dhcp excluded-address 192.168.169.200 192.168.169.255
ip dhcp pool voice
network 192.168.169.0 255.255.255.0
default-router 192.168.169.254
dns-server 208.67.222.222 208.67.220.220
option 150 ip 192.168.169.254
ip dhcp pool data
network 192.168.168.0 255.255.255.0
default-router 192.168.168.254
no ip bootp server
no ip domain lookup
ip name-server 208.67.222.222
ip name-server 208.67.220.220
interface ATM0/0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0/0.35 point-to-point
bandwidth 320
no ip redirects
no ip unreachables
no ip proxy-arp
no snmp trap link-status
pvc 0/35
vbr-nrt 320 320
tx-ring-limit 3
service-policy output ADSL
max-reserved-bandwidth 100
pppoe-client dial-pool-number 1
interface FastEthernet0/0
description LAN Interface
ip address 192.168.168.254 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
no ip mroute-cache
duplex auto
speed auto
no mop enabled
interface FastEthernet0/0.20
encapsulation dot1Q 20
ip address 192.168.169.254 255.255.255.0
ip helper-address 192.168.168.254
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
no ip mroute-cache
interface Service-Engine0/0
ip unnumbered FastEthernet0/0.20
service-module ip address 192.168.169.253 255.255.255.0
service-module ip default-gateway 192.168.169.254
interface FastEthernet0/1
shutdown
interface Dialer1
description ADSL Dialer Interface
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication pap callin
ppp pap sent-username ******************* password 7 ***********************
ppp ipcp dns request
ppp ipcp route default
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 192.168.169.253 255.255.255.255 Service-Engine0/0
ip http server
ip http authentication local
no ip http secure-server
ip http path flash:
ip nat inside source list 1 interface Dialer1 overload
ip nat inside source static tcp 192.168.168.202 80 99.138.112.54 80 extendable
ip nat inside source static tcp 192.168.168.202 5721 99.138.112.54 5721 extendable
access-list 1 permit 192.168.0.0 0.0.255.255
dialer-list 1 protocol ip permit
telephony-service
ip source-address 192.168.169.254 port 2000
show ip route:
Gateway of last resort is a.b.113.254 to network 0.0.0.0
a.0.0.0/32 is subnetted, 2 subnets
C a.b.113.254 is directly connected, Dialer1
C a.b.112.54 is directly connected, Dialer1
C 192.168.168.0/24 is directly connected, FastEthernet0/0
192.168.169.0/24 is variably subnetted, 2 subnets, 2 masks
S 192.168.169.253/32 is directly connected, Service-Engine0/0
C 192.168.169.0/24 is directly connected, FastEthernet0/0.20
S* 0.0.0.0/0 [1/0] via a.b.113.254
Thanks.
paolo bevilacqua
Hi, int se0/0 should have ip nat inside.
But, if it's just for ntp, configure the router with ntp and make the cue reference to it.
Also remember to put an access-list blocking SIP and H323 on the internet interface else you can be subject to toll fraud.
Thank you! That did it. I completely overlooked the nat!
Can you give me an example on the SIP/H323 blocking?
I really appreciate the help!
Good to know it helped. A simple access list can be like:
access-list 100 deny udp any any eq 5060
access-list 100 deny tcp any any eq 5060
access-list 100 deny tcp any any eq 1720
access-list 100 permit ip any any
interface dialer0
ip access-group 100 in
Thanks for the nice rating and good luck!
