Got signal and associated but authentication failing
Mar 22nd, 2008
I'm running Windows 2003/IAS/RADIUS with a single AIR-AP1232AG-A-K9. Everything is setup for PEAP (EAP-MSCHAP V2). When I try to authenticate it fails. I'm REAL new to this so I'm hoping someone can shed some light on this. Thanks in advance to anyone that can help. I've attached some debug info from the AP:
bwilmoth Thu, 03/27/2008 - 12:29
  • Silver, 250 points or more
If fast reconnect is enabled on the clients, make sure this is disabled, as this only
works with LEAP now.
If you have WDS enabled on the AP, please disable, it only works with LEAP.Also, you need to have at least one static WEP key defined, this key will be used as the initial broadcast key given to all clients. The key should be of 128bit length and in key slot 1.
rileymartin Thu, 03/27/2008 - 19:07
Thanks for the reply.
On the web interface I selected EAP Authentication and typed in the address of the RADIUS server as well as the RADIUS secret. Then I clicked on WPA and typed in hte RADIUS address and secret again.
I read that WPA was better than WEP. Is this right? Is this working the way I think it is? Thanks.
Scott Fella Sat, 03/29/2008 - 10:33
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
When implementing 802.1x you need to setup WPA or WPA2 as the layer 2 authentication. WPA is better than WEP, but WPA-PSK has also been compromised. This link might help:
http://www.cisco.com/en/US/products/hw/wireless/ps4570/products_configuration_example09186a00801bd035.shtml
Trending Topics - Security & Network
