03-22-2008 10:23 PM
I purchased a ASA 5505 (ASA5505-BUN-K9) a few months later I upgraded it with a Security Plus License (ASA5505-SEC-PL). But my user counts are still at 10. If I had purchased (ASA5505-SEC-BUN-K9) the user counts are unlimited. Doesn't the Security Plus convert a standard ASA 5505 to the SEC-BUN-K9. I feel like I am short changed.
03-22-2008 11:21 PM
I believe when you enter/upgrade the license you would need to restart the firewall for new license to take effect, when you do show version what does it say, can you post the output of show version , ASA5505-SEC-PL should give you unlimited users, dmz support etc..
Rgds
Jorge
03-23-2008 12:04 AM
This is what I get from show version
Licensed features for this platform:
Maximum Physical Interfaces : 8
VLANs : 20, DMZ Unrestricted
Inside Hosts : 10
Failover : Active/Standby
VPN-DES : Enabled
VPN-3DES-AES : Enabled
VPN Peers : 25
WebVPN Peers : 2
Dual ISPs : Enabled
VLAN Trunk Ports : 8
AnyConnect for Mobile : Disabled
AnyConnect for Linksys phone : Disabled
Advanced Endpoint Assessment : Disabled
This platform has an ASA 5505 Security Plus license.
03-23-2008 06:33 AM
I have same model as yours running version code 8.03, see the difference in inside hosts field..
Inside Hosts : Unlimited
VPN-DES : Enabled
VPN Peers : 25
WebVPN Peers : 2
Dual ISPs : Enabled
It could be possible the code you are running is not reading license right, I have another same model with the bun-k9 10 user lincense and I get restrictions when connections from inside exceed 10 concurrent outbound connections.
Are you getting any restrictions of any kinds connecting outbound? what code are you running.
03-23-2008 10:17 AM
I purchased the ASA5505-BUN-K9 which contains the 10 user licenses. Then I realized I needed the Dual ISP support. I ordered the ASA5505-SEC-PL license to upgrade my BUN-K9. After the upgrade I run show version and that is what I get. But the ASA5505-SEC-BUN-K9 has unlimited users. After the upgrade shouldn't the user count changed to Unlimited?
