Invalid Provider Name error with Cisco Clean Access
Mar 23rd, 2008
Hi all,
I'm very new to Cisco NAC so please bear with me. Trying to deploy a Cisco CAS and a Cisco CAM in OOB VG mode. I've added the CAS into the CAM. However when I try to access the CAS web page directly (i.e. through browser https://<CAS IP> and login, it will always fail with a "Invalid Provider Name" error. Why is this happening?
Do I need to add the VLAN into the Managed Subnet?
Another question, can I use the same vlan for both CAS and CAM management? At the moment I'm using 10.1.1.2 and 10.1.1.3 for the CAM and CAS respectively. So far I can manage the CAS from the CAM.
Overall Rating: 3 (1 ratings)
jvr775 Tue, 03/25/2008 - 14:55
wkw,
for managing the cas directly, have you tried https://cas ip/admin?
for the second question, cas trusted and cam should be on different vlans
wkw Sun, 03/30/2008 - 17:14
Thanks JVR775,
I tried https://casip/admin and it worked...also did a couple of things including changing the cam and cas trusted vlans to different ones, creating roles for authenticated users. It worked to some extent , at least now my test client can connect and authenticate via the NAC. However there were still some bugs, but that might be coz i'm using version 4.1.2 for the CCAS and CCAM, in VG OoB. Will try to download the latest and test it out. Thanks!
