High CPU utilization one-way
Mar 23rd, 2008
  • Silver, 250 points or more
LinuxES-1----(F0/1)Cisco7120_Router(F0/0)----LinuxES-2
LinuxEs_1 IP is 192.168.1.10
LinuxES_2 IP is 4.2.2.3
C7140 IOS version: c7100-jo3s-mz.123-12e.bin
interface F0/1
ip nat inside
speed 100
duplex ful
interface F0/0
ip address 4.2.2.2 255.255.255.0
ip address outside
speed 100
duplex full
ip nat outside
access-list 100 permit ip 192.168.1.0 0.0.0.255 any
ip nat inside source list 100 interface F0/0 overload
ip nat inside source static tcp 192.168.1.10 22 interface FastEthernet0/0 22
Everything is connected to a Catalyst 3750 FastEthernet switch.
If I download a large file from LinuxES_1 to LinuxES_2 via SCP and I do it from
LinuxES_1, I get about 8.6MBytes/sec upload. CPU on the router is:
LAB>sh process cpu
CPU utilization for five seconds: 40%/39%; one minute: 40%; five minutes: 40%
If I uploaded a large file from LinuxES_2 to LinuxES_1 via SCP and I do it
from LinuxES_2, I get about 5.2MBytes/sec upload. CPU on the router is:
LAB>sh process cpu
CPU utilization for five seconds: 99%/98%; one minute: 98%; five minutes: 98%
Basically, I am getting half the transfer speed because the router CPU is
at 99% CPU utilization. I don't understand why direction is important in
this case.
Both of these Linux servers are Dell with dual quad-core processors with
8GB RAM and 10k RPM so read/write latencies is not a factor here.
If I put both servers on the same subnet and perform scp, I get about
11.8MBytes/sec transfer each way.
Anyone know why the router behaves this way. Thanks.
Joseph W. Doherty Sun, 03/23/2008 - 06:08
In this instance, I would suspect NAT is sensitive to flow direction.
It isn't clear whether you're "pushing" or "pulling" from each host to the other, or "pushing" and "pulling" from the same host. (i.e. former like LinuxES-1 sends/gets from LinuxES-2 followed by LinuxES-2 does same to LinuxES-1 vs. LinuxES-1 sends to LinuxES-1 followed by LinuxES-1 gets from LinuxES-2.) It might make a difference. I would also wonder about the impact of "overload".
[edit]
Rereading your post, I see LinuxES-1 gets from LinuxES-2 and LinuxES-2 sends to LinuxES-1. Correct?
cisco24x7 Sun, 03/23/2008 - 06:58
That's correct.
I am on the LinuxES-1 console, I performed
"scp [email protected]:/var/ftp/large .", I get
8.6MBytes/sec (68.8Mbits/sec) download,
pulling or getting data
I am on the LinuxES-2 console, I peformed
"scp large [email protected]:/var/ftp/.", I get
5.2MBytes (41.6Mbits/sec) upload, pushing or
sending data.
I noticed that this is also true with other
traffics as well such as FTP and Iperf. In
other words, anything that leaving the
router, I get very good wire-speed and CPU
never goes beyond 50% utilization. Anything
coming into the router, the traffics never
goes beyond 5.2MBytes/sec and CPU is at 99%
utilization.
Any ideas on how to improve this gentlemen?
Thanks.
cisco24x7 Sun, 03/23/2008 - 15:12
As a follow-up, I replaced the Cisco 7140
with a VXR7204 and the traffic is about the
same as before. No improvement. The IOS
version on the VXR7204 is 12.4(16) Advanced
IP Services.
I then replaced the VXR7204 with a Checkpoint
Firewall NGx R65 Secureplatform running on a
Dell Server 2550, dual processors 1.0Ghz
with 2GB RAM. The NAT setup on the
Checkpoint is identical to the NAT on the
Cisco 7140 and VXR7204. My throughput goes
up to 11.1MBytes/sec sending and receiving.
Apprently, NAT works differently between
Checkpoint and Cisco. Apparently, from
what I can see, it consumes more CPU on
Cisco than on Checkpoint. Then again,
the architecture is different,
the dell box has much more memory, 2GB RAM
versue 256MB RAM on the Cisco VXR7204, so my
assumption may not be a correct one.
I am going to test this tomorow with a
Cisco Pix525 and see if I see the same
result.
will keep everyone posted.
CCIE Security
