Cisco ASA, RDP plugin authentication
Answered Question
I've installed an ASA 5505 (8.0.3) with WEBVPN. I've managed to get everything working with SSO (Single Sign On) except for the terminal rdp session. Owa, sharepoint, filebrowsing, SSO is no problem, but I don't seem to get it working with RDP. Somehow it doesn't translate the variables to the rdp session. I'm using CSCO_WEBVPN_USERNAME and CSCO_WEBVPN_PASSORD, but they appear just like that in the username/password field. Is there any way to make SSO work for RDP?
Correct Answer by snooter about 9 years 1 week ago
ofwegen, just so you know I'm not using a single signon server, just auto signon, and I got this to work with the rdp plugin by editing the bookmarks to have the "csco_sso=1" option in there:
rdp://myterminalserver/?csco_sso=1
This works for both ICA and the RDP plugins.
Overall Rating: 5 (1 ratings)
htarra Fri, 03/28/2008 - 09:08
  • Bronze, 100 points or more
First try fixing asdm, go to firewall command line and see where your asdm upgrade image landed "dir", most likely it landed in disk0, if that is the case do " show run | inc asdm" to see current firewall asdm statement and correct as follows.
asa for ssh follow this link.( use aaa authentication local )
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a008069bf1b.shtml#configs
snooter Thu, 04/03/2008 - 13:22
ofwegen, sorry I don't have a fix for you, but if you happen to find the fix for SSO using RDP, please post what you find. I've been working on this same thing now for about two months.
I'll post back of couse if I find the remedy.
Correct Answer
snooter Wed, 04/16/2008 - 04:41
Hello Patrick,
For as far as I know, it's not documented anywhere near the RDP plugin. What is does is simple. It translates the Cisco username/password variable to the variables used in the RDP plugin (this is thirt party software). The csco_sso feature is documented near the Citrix plugin, you could see if any usefull information can be found there.
Leon
