Cisco 877 K9 Router - Wan Problem - router "Clicking"
Hi for all supporters out there :).
well...
I got a cisco 877 k9 router.
And it's seems that the wan interface
A-K-A atm0 is not working
In addition whenever I turn it on
(no shutdown) it's "clicking" like a little clock every 5 seconds
The configuration is OK.. trust me.. :D
I work 3 years now in ISP, and I'm configuring CISCO routers every day...
The ADSL line (infrastructure) is also fine.
the original modem that i got with the line works just fine
I can't find any problem..
Did write erase.. and nothing..
the problem emerges again and again...
plz HELP ...
thx all in advance.. !!
technical info:
C870-ADVSECURITYK9-M Version 12.3(8)YI2
flash:c870-advsecurityk9-mz.123-8.YI2.bin
Cisco 877 (MPC8272) processor (revision 0x100) with 118784K/12288K
Processor board ID FHK0947216W
Overall Rating: 2 (1 ratings)
Edison Ortiz Sun, 03/23/2008 - 09:44
  • Hall of Fame,
    Founding Member
Sounds like a hardware problem, please open a case with TAC.
__
Edison.
Paolo Bevilacqua Sun, 03/23/2008 - 11:36
  • Hall of Fame,
    Founding Member
Hi, clicking noise is due to the DSL line relays attempting to reset the line periodically.
Your router is not connecting due to old IOS and DSL firmware.
Since I suppose you have no access to software download, please access the freely available DSL firmware upgrade:
ftp://ftp.cisco.com/pub/access/800
The one you want is 3-0-33, there is a doc file that explains how to install it.
After that, if still trouble please send output of "show dsl interface".
Hi again.
well I contact TAC, as u advised.
And A tech support Representative contact me.
I showed him this conversation and he sent me the last ISO for the embedded modem.
nothing happened.
the clicks just come and go in bigger intervals
I've Attached some outputs to some commands.
I hope you guys out there can Help and Assist
Best Regards
OFIR
Paolo Bevilacqua Mon, 03/24/2008 - 03:40
  • Hall of Fame,
    Founding Member
You have loaded the wrong external DSL firmware (4.x). The one that was needed is 3-0-33 as I mentioned before.
Delete the firmware filed and reboot. If trouble, send "show dsl interface again".
Hi p.bevilacqua .
thank you again for the assistance !
the IOS for the modem that I first installed was sent to me by Paul Vazquez - Cisco TAC - Architecture - [email protected]
and now I've installed the other modem IOS
file name adsl_alc_20190.3-0-33.bin
and the only change I saw is the status on "sh ip int bri" - the status changed from "down" to "initializing".
but it's stuck there and no change.
it wont sync .
I will be more then happy to hear from you ASAP
Best Regards
Ofir Even
Router#sh dsl int atm0
ATM0
Alcatel 20190 chipset information
Line has not yet been activated.
Modem Status: Down (DMTDSL_DO_OPEN)
DSL Mode: Unknown
Interrupts: 8210 (0 spurious)
PHY Access Err: 0
Activations: 0
LED Status: OFF
LED On Time: 100
LED Off Time: 100
Init FW: init_3.0.33_nobist.bin
Operation FW: AMR-3.0.033.bin
FW Source: external
DSL: Training log buffer capability is not enabled
Router#sh ip int bri
FastEthernet0 unassigned YES unset up up
FastEthernet1 unassigned YES unset up down
FastEthernet2 unassigned YES unset up down
FastEthernet3 unassigned YES unset up down
ATM0 unassigned YES NVRAM initializing down
Vlan1 192.168.5.1 YES NVRAM up up
Dialer0 unassigned YES NVRAM up up
Paolo Bevilacqua Mon, 03/24/2008 - 04:27
  • Hall of Fame,
    Founding Member
There is one last firmware that you can try, 3.0.39
ftp://:@ftp.cisco.com/cisco/access/800/adsl_alc_20190.bin.3-0-39
If you don't have CCO download access, ask Paul to send it to you.
