ssh question
Mar 23rd, 2008
I need to access a Linux server that sits behind an 871w router. I can ssh to the router from the server but cannot ssh to the router or server from the outside. Any idea where to start?
Thank you,
John
Overall Rating: 1 (1 ratings)
Edison Ortiz Sun, 03/23/2008 - 12:01
  • Hall of Fame,
    Founding Member
You can start by posting the router config.
__
Edison.
jseneca64 Sun, 03/23/2008 - 13:02
I uploaded the config. The ip address of the server I need to ssh to is 10.0.1.99.
Thanks for your response,
John
cisco24x7 Sun, 03/23/2008 - 13:58
  • Silver, 250 points or more
ip nat inside source static tcp 10.0.1.10 22 interface FastEthernet4 22
Now from the outside, anyone connecting to the router FastEthernet 4
interface IP on port 22 will be re-direct to the Linux server, assuming
that host 10.0.1.10 is the IP address of the linux server
jseneca64 Sun, 03/23/2008 - 17:10
I made added the nat route but still no connection from the outside. Attached is my current running config. Am I missing something? My server IP is 10.0.1.99.
Thank you,
John
cisco24x7 Sun, 03/23/2008 - 17:19
Please modify your ACL as such:
ip access-list extended Internet-inbound-ACL
permit udp any eq bootps any eq bootpc
permit icmp any any echo
permit icmp any any echo-reply
permit icmp any any traceroute
permit gre any any
permit esp any any
permit tcp any any eq 22 log
deny ip any any log
That will ssh access from the outside.
CCIE Security
jseneca64 Sun, 03/23/2008 - 17:55
Made the changes and I can now ssh from the outside. Did I need the ip nat inside source static tcp 10.0.1.10 22 interface FastEthernet4 22 line added to the config? Thank you so much for your help!
John
cisco24x7 Sun, 03/23/2008 - 18:18
you need both:
you can even ssh into your linux box on whatever port your specified
if you want preserve tcp port 22 to ssh into your router from the
outside. For example, you can do this
ip nat inside source static tcp 10.0.1.99 22 interface FastEthernet4 24
deny ip any any log
permit tcp any any eq 24 log
deny ip any any log
Now you can ssh into your router on tcp port 22 and your Linux server
on tcp port 24. Putty, Teraterm or SecureCRT can do it rather easily.
CCIE Security
