Recomendations for lab equipment for CCNP & CCIE R&S.
Mar 23rd, 2008
steve_steele Sun, 03/23/2008 - 22:24
For CCIE R&S you need something like the following to simulate a full lab and follow a vendor workbook such as ipexpert / internetexpert etc
1 x 2511 Access Server
6 x 2600 Routers ( Maxed out with flash and Ram ) The XM routers are a good choice. you'll want 2 with 2 Ethernet Interfaces on.
2 x 3550 Switches
2 x 3560 Switches ( The Eight port versions are pretty cheap )
1 x Frame Relay Switch - I use a 2500 with NM-8A/S
1 x 2500 to use as a backbone router to inject routes for redistribution.
The Access Server and Frame Switch can also be used to inject routes.
You can rent online which is much cheaper but I found that It's a lot easier to study whenever you have time free if you are in total control of your own rack.
