IPIPGW Lab
Mar 23rd, 2008
I have set up a small LAB for IPIPGW, i can go through it with G711 but when i begin to manipulate the codec, like using using G729 it does not work.
what i need to do:
1) CCM 1 (G711) IPIPGW (G729) CCM2;
I have transcoding for CCM1, CCM2 and for the IPIPGW running but no luck
2) CCM1 104 calls CCM2 7002 get a busy tone when off hook.
I donno what i am missing???
Good day
gogasca Sun, 03/23/2008 - 12:14
  • Green, 3000 points or more
Could you please upload
debug voice ccapi ino
debug h225 asn1
debug h225 q931
debug h245 asn1
Please?
twissam Sun, 03/23/2008 - 12:27
attached are the debugs. i have noticed something during my tests as follow
CCM1 (G711) icoming Dial-Peer IPIPGW (G711)
Outgoing DIal-Peer IPIPGW (G729) CCM1 (G729) this combination works
and i see transcoding done by the IPIPGW from G729 to G711. Why i cannot make CCM1 (ICT as G711)!!!
Good day
twissam Sun, 03/23/2008 - 12:33
Outgoing DIal-Peer IPIPGW (G729) CCM2 (G729) this combination works
and i see transcoding done by the IPIPGW from G729 to G711. Why i cannot make CCM2 (ICT as G711)!!!
Sorry it should be CCM2. The other annoying part as well is that when G729 in CCM2 i cannot use the hold, transfer, etc... please note that the MTP is checked for both ICT Non GK controlled.
Good day
