03-23-2008 06:44 PM - edited 03-15-2019 09:35 AM
I am trying to configure a SIP account on my 2801 ISR Router using the CUBE functionality. I have tried all possible configuration combinations but it does not seem to register. The account works fine if I use a softphone such as X-Lite. My configuration details are as follows:
sip-ua
authentication username xxxxxxxxxx password xxxxxxxxxx realm byo.engin.com.au
credentials username xxxxxxxxxx password xxxxxxxxxx realm byo.engin.com.au
registrar dns:byo.engin.com.au expires 3600
sip-server dns:byo.engin.com.au
My Voip service provider is engin and the settings they provided me for an Asterisk setup were:
auth=md5
canreinvite=yes
dtmfmode=rfc2833
fromdomain=voice.mibroadband.com.au
fromuser=XXXXXXXXXX
host=byo.engin.com.au
insecure=very
musiconhold=framed
nat=yes
port=5060
qualify=no
realm=mobileinnovations.com.au
reinvite=yes
secret=password
type=friend
username=XXXXXXXXXX
Some explanation on
1) authentication vs credentials and
2) as well registrar vs sip-server
under sip-ua configuration would be much appreciated.
03-24-2008 04:01 AM
1 authentication is for placing calls, credential to register.
2 registar is what handles registrations INTO router. sip-sever handles calls. How course the two things are tied.
now for the proble, do you have an Ip-to-ip image (filename ends in _ivs) ? NAd what specific problem do you have (can't register, can't call or what) ?
03-25-2008 02:54 AM
Thanks for the info. I have the following IOS: c2801-ipvoice_ivs-mz.124-15.T3.bin
The problem is that it does not register at all.
03-25-2008 04:44 AM
Can you collect "debug ccsip message"?
03-26-2008 12:05 AM
************Configuration***************
sip-ua
credentials username xxx password xxx realm dns:mobileinnovations.com.au
authentication username xxx password 12345 realm dns:mobileixxx.com.au
retry options 1
registrar dns:byo.engin.com.au expires 900
************Error from debug ccsip************
SIP/2.0 407 Proxy Authentication Required
To: <>0390170000@voice.mibroadband.com.au>;tag=ds33af16c>
From: <>0390170000@voice.mibroadband.com.au>;tag=1AE749F0-1079>
Via: SIP/2.0/UDP 192.168.100.68:5060;branch=z9hG4bK17EAD2
Call-ID: 312B86F3-FA3911DC-8235F0DB-1DB97FC5
CSeq: 4 REGISTER
Date: Wed, 26 Mar 2008 07:00:28 GMT
Proxy-Authenticate: Digest realm="mobileinnovations.com.au",domain="sip:byo.engi
n.com.au:5060",nonce="xuQCcKjtvrRVuayrJq4kIg==_40f0",qop="auth"
Content-Length: 0
03-26-2008 03:06 AM
Router should continue with another registration message containing authentication, does not ?
03-26-2008 01:53 PM
03-29-2008 05:18 PM
I did some further troubleshooting and realised that the config on the router is perfect. When I use an ADSL connection, the SIP trunk registers well. However, when I use the corporate internet connection which is a secure MPLS service, it does not work. I requested the ISP to forward udp ports 5060 and 16384-20384 to the router ip address. Despite this, it does not work. Is there something more to be done? Config and debug files attached.
