ASA5510 Failover MPLS and DLL
Mar 24th, 2008
Hello All,
I would just like to ask if it is possible for the ASA5510 to do failover?
Our Client is using a single ASA5510 and currently their WAN link is using a dedicated leased line connection and now they are going to use an mpls connection and they would like to make the existing leased line connection to be their backup line.
How would I go about doing this? Would I just do some routing changes and add metrics to it? Do I need to have a heartbeat so that the failover would take place?
Or doing a failover with two wan links (MPLS and DLL) on a single ASA would not work?
Thank you for your reply! Have a nice day!
lawrence
JORGE RODRIGUEZ Mon, 03/24/2008 - 18:42
  • Green, 3000 points or more
If I understand correctly, your company will migrate to MPLS with a new circuit, and their existing internet link they will like to keep it, company want to use old circuit as a backup while the MPLS link would be their primary, if this is correct you can try this link..if new MPLS is one ISP provider and old lease line is different ISP.
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00806e880b.shtml
