cleaning up Dial peers
Answered Question
Mar 24th, 2008
Can someone help me out. I know that the 5184 and 3155 dial peer we are using for fax fxs cards. I don't know what the other Dial peers are for. And I want to clean them up.
We just moved to a new location and we just got a PRI. D
Correct Answer by mattcalderon about 9 years 3 days ago
This one is for direct dialing of 17162896926
Dial-peer voice 9999 pots
destination-pattern 17162896926
This one is for dialing out to your PRI using the outbound access code of 8.
dial-peer voice 10 pots
preference 1
destination-pattern 8T
This is for 911 dialing.
both dial-peers 8911 and 911 are for dialing 911
Dial peers 100, 101 and 200 are for 4 digit dialing across the WAN to your pub and sub more than likely.
dial-peer 300 and 301 are shut down but is used to send extension 3155/2975 across the wan to either a ccm or another gateway.
Dial-peer 2975 will send numbers to 17166262617 across the pri.
the rest of the dial-peers with port 0/2/0, 0/2/1, and 0/2/2 are used to send four digits out those mandated ports. Those can either be FXO or FXS ports.
good info for dial-peer configuration and understanding!
http://www.cisco.com/en/US/docs/ios/12_2/voice/configuration/guide/vvfpeers.html#wp1241411
Overall Rating: 5 (1 ratings)
Correct Answer
mattcalderon Mon, 03/24/2008 - 07:28
  • Silver, 250 points or more
preference 1
