IP Communicator 2.1.3
Mar 24th, 2008
How to disable the Web access, please provide the steps for the same...
Web access enable option cannot be changed to No on the security configuration.
appriciating for quicker response...
mattcalderon Mon, 03/24/2008 - 07:54
  • Silver, 250 points or more
set up ACL blocking 80 using either the IP of the communicator or the CCM as the host.
ajkhader123 Mon, 03/24/2008 - 08:05
I am trying to access an application which is installed on my local PC with the following URL http://localhost, when the ip communicator is on it takes me to the Device configuration screen insted of the application, if i block the port 80 will i be able to access the application.
Thanks...
ajkhader123 Mon, 03/24/2008 - 08:19
is there any posibilty for the ip communicator to listen to a different port since i cannot change the port for the application.
