Rob Huffman Mon, 03/24/2008 - 08:33
Hi Ricardo,
Hope all is well :) It must be entered this way;
csim start
Note: start not star
Hope this helps!
Rob
mattcalderon Mon, 03/24/2008 - 09:14
example:
csim start 918005464454
/endexample
Use the above only input your own information.
Note: This can only be used with H323 gateways and then only if you have your dial-peers configured correctly.
MC
ricardorojas123 Mon, 03/24/2008 - 12:38
I enter the command but the phone don't ring.
The dial-peer is configured in the Gateway.
The phone is registered in the Call Manager Express.
And this message is show:
Router#csim start 2001
csim err:csim_do_test invalid major major(16) minor(0)
mattcalderon Mon, 03/24/2008 - 12:39
Is the DN you are trying to call part of your ephone configuration? I am not sure if you can use the csim start command to call an ephone vs a regular analog line or PRI. I could be wrong. Paulo or Rob may know though.
ricardorojas123 Mon, 03/24/2008 - 12:46
Is a Call Manager Express version 4.1 in a Router 2800, and this have the dial-peer configured.
