accumulated statistics
Mar 24th, 2008
Is there a command on the ASAs similar to the show ip accounting command found on IOS routers? Something showing source, destination, packets and bytes pertaining to those source/destination connections that accumulates?
thank you,
Bill
Overall Rating: 4 (1 ratings)
Jay Johnston Mon, 03/24/2008 - 11:15
  • Cisco Employee,
The closest thing you're going to get is the 'show local-host' command, which will show you all the connections associated with a particular IP address.
Aggregate counters include 'show traffic', 'show perfmon'.
One way to get this same data (although sometimes memory intensive) is to use the new threat-detection feature. Look it up in the command reference for more information.
