6500 VSS
Mar 24th, 2008
I'm thinking of deploying VSS in an environment with 200+ servers and 5 IDFs. I'd like to get some feedback.
Can anyone comment on a deployment?
How complex is it? Any bugs found?
Is it ready for prime time?
jaye15394 Fri, 03/28/2008 - 12:44
Owen, I'm quite familiar with the system. Reading the literature shouldn't make you at ease for deploying it in a prod environment :)
Edison Ortiz Fri, 03/28/2008 - 12:35
  • Hall of Fame,
    Founding Member
As with any new deployment, I recommend contacting your Cisco Sales Rep and see if they let you test drive it before making a final decision on the purchase.
I know several corporations already using VSS.
As for bugs, well if you work in IT, you will always have bugs. It's called job security :)
__
Edison.
jaye15394 Fri, 03/28/2008 - 12:46
Hey Edison,
Thanks for the post. I just left the role of an SE at Cisco a few months ago and I will for sure contact my Account Team :) The technology is great, but want to make sure it's solid.
Can you comment on safe harbor testing?
Jason
