Campus Manager - bpdufilter/bpduguard and portfast
luizmmb
I have problem with my Campus Manager installation. The Physical Discrepancy Report show these messages:
Port Fast Enabled on Trunk Port
BPDU-Guard disabled on access ports
BDPU Filter disabled on access ports
But my swicthes are OK. It seems that CM ignore the default configuration:
spanning-tree portfast default
spanning-tree portfast bpduguard default
spanning-tree portfast bpdufilter default
Do you have any idea ?
ps: My Campus version version is 4.0.10. The swicthes are 2950 with IOS 12.1(22)EA11.
8 Replies 8
Joe Clarke
There was a bug that would account for the two BPDU discrepancies, but that was fixed in CM 4.0.8. A new Campus Data Collection after upgrading to 4.0.8 or higher should have removed those discrepancies. Therefore, it would be helpful to see the running-config from this switch as well as the complete discrepancy details.
Here is the configuration of one of my 2950. I erase some line (password, etc) but the most important is there.
I am posting the Physical Discrepancy Details Report. I hope this can help.
Please provide an SNMP Walk starting at c2900PortSpantreeFastStart (.1.3.6.1.4.1.9.9.87.1.4.1.1.36) from this switch.
This is the snmp walk that you asked for. I think that the swicth 2950 is sending wrong values.
2950 - ciscoC2900
OID: .1.3.6.1.4.1.9.9.87.1.4.1.1.36.0.1
Value: disabled
OID: .1.3.6.1.4.1.9.9.87.1.4.1.1.36.0.2
Value: disabled
OID: .1.3.6.1.4.1.9.9.87.1.4.1.1.36.0.3
Value: disabled
OID: .1.3.6.1.4.1.9.9.87.1.4.1.1.36.0.4
Value: disabled
OID: .1.3.6.1.4.1.9.9.87.1.4.1.1.36.0.5
Value: disabled
OID: .1.3.6.1.4.1.9.9.87.1.4.1.1.36.0.6
Value: disabled
OID: .1.3.6.1.4.1.9.9.87.1.4.1.1.36.0.7
Value: disabled
OID: .1.3.6.1.4.1.9.9.87.1.4.1.1.36.0.8
Value: disabled
OID: .1.3.6.1.4.1.9.9.87.1.4.1.1.36.0.9
Value: disabled
OID: .1.3.6.1.4.1.9.9.87.1.4.1.1.36.0.10
Value: disabled
OID: .1.3.6.1.4.1.9.9.87.1.4.1.1.36.0.11
Value: disabled
OID: .1.3.6.1.4.1.9.9.87.1.4.1.1.36.0.12
Value: disabled
OID: .1.3.6.1.4.1.9.9.87.1.4.1.1.36.0.13
Value: disabled
OID: .1.3.6.1.4.1.9.9.87.1.4.1.1.36.0.14
Value: disabled
OID: .1.3.6.1.4.1.9.9.87.1.4.1.1.36.0.15
Value: disabled
OID: .1.3.6.1.4.1.9.9.87.1.4.1.1.36.0.16
Value: disabled
OID: .1.3.6.1.4.1.9.9.87.1.4.1.1.36.0.17
Value: disabled
OID: .1.3.6.1.4.1.9.9.87.1.4.1.1.36.0.18
Value: disabled
OID: .1.3.6.1.4.1.9.9.87.1.4.1.1.36.0.19
Value: disabled
OID: .1.3.6.1.4.1.9.9.87.1.4.1.1.36.0.20
Value: disabled
OID: .1.3.6.1.4.1.9.9.87.1.4.1.1.36.0.21
Value: disabled
OID: .1.3.6.1.4.1.9.9.87.1.4.1.1.36.0.22
Value: disabled
OID: .1.3.6.1.4.1.9.9.87.1.4.1.1.36.0.23
Value: disabled
OID: .1.3.6.1.4.1.9.9.87.1.4.1.1.36.0.24
Value: disabled
OID: .1.3.6.1.4.1.9.9.87.1.4.1.1.36.0.25
Value: disabled
OID: .1.3.6.1.4.1.9.9.87.1.4.1.1.36.0.26
Value: disabled
OID: .1.3.6.1.4.1.9.9.87.1.4.1.1.36.0.27
Value: disabled
OID: .1.3.6.1.4.1.9.9.87.1.4.1.1.36.0.28
Value: disabled
OID: .1.3.6.1.4.1.9.9.87.1.4.1.1.36.0.29
Value: disabled
OID: .1.3.6.1.4.1.9.9.87.1.4.1.1.36.0.30
Value: disabled
OID: .1.3.6.1.4.1.9.9.87.1.4.1.1.36.0.31
Value: disabled
OID: .1.3.6.1.4.1.9.9.87.1.4.1.1.36.0.32
Value: disabled
OID: .1.3.6.1.4.1.9.9.87.1.4.1.1.36.0.33
Value: disabled
OID: .1.3.6.1.4.1.9.9.87.1.4.1.1.36.0.34
Value: disabled
OID: .1.3.6.1.4.1.9.9.87.1.4.1.1.36.0.35
Value: disabled
OID: .1.3.6.1.4.1.9.9.87.1.4.1.1.36.0.36
Value: disabled
OID: .1.3.6.1.4.1.9.9.87.1.4.1.1.36.0.37
Value: disabled
OID: .1.3.6.1.4.1.9.9.87.1.4.1.1.36.0.38
Value: disabled
OID: .1.3.6.1.4.1.9.9.87.1.4.1.1.36.0.39
Value: disabled
OID: .1.3.6.1.4.1.9.9.87.1.4.1.1.36.0.40
Value: disabled
OID: .1.3.6.1.4.1.9.9.87.1.4.1.1.36.0.41
Value: disabled
OID: .1.3.6.1.4.1.9.9.87.1.4.1.1.36.0.42
Value: disabled
OID: .1.3.6.1.4.1.9.9.87.1.4.1.1.36.0.43
Value: disabled
OID: .1.3.6.1.4.1.9.9.87.1.4.1.1.36.0.44
Value: disabled
OID: .1.3.6.1.4.1.9.9.87.1.4.1.1.36.0.45
Value: disabled
OID: .1.3.6.1.4.1.9.9.87.1.4.1.1.36.0.46
Value: disabled
OID: .1.3.6.1.4.1.9.9.87.1.4.1.1.36.0.47
Value: disabled
OID: .1.3.6.1.4.1.9.9.87.1.4.1.1.36.0.48
Value: disabled
OID: .1.3.6.1.4.1.9.9.87.1.4.1.1.36.0.49
Value: enabled
OID: .1.3.6.1.4.1.9.9.87.1.4.1.1.36.0.50
Value: enabled
It sure looks like the switch says you have portfast enabled on Gi0/1 and Gi0/2. Please post a walk of the whole c2900PortTable and a walk of ifDescr.
OK.
It looks like a bug when spanning-tree portfast default is enabled. Any port which does not have any explicit portfast configuration is listed as disabled in the C2900-MIB. If a port has spanning tree disabled explicitly, then the MIB reflects its status as enabled.
You can test this by removing the two spanning-tree portfast disabled commands under your trunk ports. After another Campus Data Collection, the discrepancies about portfast being enabled on trunk ports should disappear.
I understand. Thanks for your help.
