CSS 11503 DFP setup questions
Mar 24th, 2008
I have a customer currently using round-robin SLB on a 11503. They are looking at implementing Dynamic Feedback Protocol (DFP) agents to try to get more granular weighting for LB decisions. Has anyone used DFP, or are you familiar with the agents available for HP Blade Servers/Windows 2003 or other OS? Has it resulted in any performance gains? We don't want to waste to many cycles if it will not give us double digit gains in performance.
Thanks!
Overall Rating: 5 (1 ratings)
Gilles Dufour Tue, 03/25/2008 - 01:59
Honestly, I have seen many attemps from different people to use DFP, but was never convinced that they got better result than leastconn.
Gilles.
ryan.schmotter@... Wed, 04/02/2008 - 10:03
So, you would recommend leastconn? My customer is using round-robin (without weighting) and they seem to be insisting on testing using DFP. We can't seem to find any doco on DFP agents for HP Servers running Windows. Does anyone have any knowledge of DFP agents for HP servers?
Gilles Dufour Thu, 04/03/2008 - 02:43
Yes, I would recommend leastconn.
The only agent I know is for IBM mainframe since DFP was developped by Cisco with the help of IBM.
I have seen people developping their own agent but nothing available on the market.
Gilles.
