DTMF Relay problem over SIP trunk and CUBE to Cisco Unity
Mar 24th, 2008
I'm running a SIP provider trunk into a CUBE setup (IPIPGW IOS) to a CUCM 6.1
All is working except when users end up in Unity Connection any DTMF's they press are followed by Unity stating "I did not recognize that as a valid entry"
The exact same handler dialer internally works fine... Even the trace from the gateway is fine...
Dial-Peers are as follows....
dial-peer voice 6112 voip
description inbound leg from SIPProvider
rtp payload-type nte 120
session protocol sipv2
incoming called-number 6112
dtmf-relay rtp-nte
codec g711ulaw
fax rate disable
dial-peer voice 7112 voip
description Outbound Leg to CUCM
destination-pattern 6112
session target ipv4:192.168.2.102
dtmf-relay h245-alphanumeric
codec g711ulaw
fax rate disable
no vad
And the H245 even sends the right stuff, did I miss something?
.Mar 24 19:12:57.006: h245_encode_userInputIndicaiton_indication
.Mar 24 19:12:57.006: h245_encode_user_input_indication: 2
bwilmoth Fri, 03/28/2008 - 12:19
  • Silver, 250 points or more
Configure the DSP resources to be able to do in-band conversion for dtmf.
Also refer this bug id for more information on DTMF issue with SIP trunks:CSCse27247
