B-ACD/AA with SRST issue
Mar 24th, 2008
I have a router in H.323 mode, with SRST configured. I am using B-ACD I changed many IOS versions but the result is the same:the script is running until the moment when it must play the audio prompts. I can see "TCL AA: ++ Playing Welcome Prompt and options menu ++" in debug, I can see the file name chosen by script is correct, but I can't hear anything on PSTN phone. I attached debug, config, sh diag and sh flash.
Any help will be highly appreciated.
Thank you,
Overall Rating: 5 (1 ratings)
smalkeric Fri, 03/28/2008 - 12:19
When a call comes from PSTN , you need to configure these commands in the CME.
Try :
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
Tomasz Hinz Sun, 07/28/2013 - 11:46
Hi, could you send me this problem information, because your link doesn't no longer working.
Tomasz Hinz
