Ethernet connection
Answered Question
Mar 24th, 2008
Hi everyone I have a quick question I have a pix 515E with an inside and outsdie interface already I'm trying to add another inside interface. I've added the ip address to ethernet2 intf2 of and the other end is a 2821 and its ethernet interface is When I'm on the pix I can ping but when I try to ping across the ethernet connection I cannot ping .51. I know you cannot say much since you don't have the config will get that soon but off the top of your heads till then am I missing something?
Correct Answer by allanc_16 about 8 years 7 months ago
I believe it should be the first port looking at the card from left to right.
Overall Rating: 5 (1 ratings)
allanc_16 Mon, 03/24/2008 - 13:17
Enable the following:
Debug icmp trace
After doing this ping the 2821 again and see if the device is responding to the ICMP packets sent from the firewall.
Also make sure that the interface us UP by doing a "show interface e2"
wgranada1 Mon, 03/24/2008 - 13:34
oh my goodness its always the simple stuff
I seem to over look. e2 is showing up down
feel like a knuckle head right now. Thank for that!!!!
wgranada1 Mon, 03/24/2008 - 13:40
Sorry one more question on a 515E I have 6 available ports I'm using 2 and the 3rd one, eth2 is coming from a card located on the top left hand corner. If I read the card and look at the PIX from behind and from right to left is eth2 the first slot or is it the last slot, the left most one?
Correct Answer
allanc_16 Mon, 03/24/2008 - 14:04
