7941 Random phone reset
2 users were on calls. Both users had dead silence on their calls at the same time, and at least one of the phones said CM unavailable, features disabled. The call came back momentarily, then there was silence again. Hung up the receiver and the phones reset.
We are using CME and the phones are 7941s. The following lines are from the cache/log of one of the phones. This message is the same on both phones which went dead and on a phone which wasn't being used at the time:
WRN 15:54:55.751547 JVM: Thread-22|cip.sccp.ce:? - Read exception: java.net.SocketException: Connection timed out: Connection timed out
Close(d) Connection ...
ERR 15:54:55.764509 JVM: 3:54:55p|java.net.SocketException: Connection timed out: Connection timed out
at cip.io.SecureInputStream.socketRead([BII)I(Native Method)
at cip.io.SecureInputStream.read([BII)I(Unknown Source)
at java.io.BufferedInputStream.fill()V(Unknown Source)
at java.io.BufferedInputStream.read()I(Unknown Source)
at java.io.DataInputStream.readInt()I(Unknown Source)
at cip.io.j.readInt()I(Unknown Source)
at cip.sccp.ar.a()Lcip/sccp/bm;(Unknown Source)
at cip.sccp.ce.e()V(Unknown Source)
at cip.sys.j.run()V(Unknown Source)
at java.lang.Thread.startup(Z)V(Unknown Source)
paolo bevilacqua Mon, 03/24/2008 - 14:57
  • Hall of Fame,
    Founding Member
Which exact IOS and phone FW ?
Crashes likes these are usually easily solved upgrading to a stable release for both.
This is from the 7941G phone:
App Load ID jar41sccp.8-0-3-32.sbn
Boot Load ID 7941G_64-02070631Amd64megRel.bin
Hardware Revision 1.0
This is from the Help>About page in Unity Express 2.3
About Cisco CallManager Express
Operating System: Cisco Internetwork Operating System. Cisco IOS (tm) C2800NM
Cisco IOS Software: C2800NM-SPSERVICESK9-M
Software Version: 12.4(9)T4 / CME 4.0(0)
paolo bevilacqua Mon, 03/24/2008 - 15:13
  • Hall of Fame,
    Founding Member
I would recommend 12.4(11)XJ4 as IOS, and SCCP41.8-2-2SR4S for the phones.
Both are direct upgrades and you have nothing to worry aabout.
