Unity 4.2 hardware model?
Mar 24th, 2008
I need to find out which exact 7800 series platform my Unity 4.2 is running on in order to purchase the correct SmartNet for it. However, all I see is 7800 series all over the place and Cisco shows a couple dozen different models. How do I tell which model I have?
Diego
Overall Rating: 5 (1 ratings)
Brandon Buffin Tue, 03/25/2008 - 05:26
  • Purple, 4500 points or more
Diego,
You can use the Service Contract Center. Go to the following link.
www.cisco.com/go/scc
Click Login to SCC. After logging in do a Quick Search by serial number.
Hope this helps. If so, please rate the post.
Brandon
DIEGO ALONSO Tue, 03/25/2008 - 07:23
That sounds like a good idea to use the SSC. Problem now is getting the serial number. I ran a report from the SA GUI that says it will include the serial number but it doesn't. I ran a couple other tools but no serial number to be found. Any ideas on how to get the serial?
Brandon Buffin Tue, 03/25/2008 - 07:28
It should be on the top of the server on a barcoded label.
Brandon
DIEGO ALONSO Wed, 03/26/2008 - 05:44
Wow, I guess I am going to have to bite the bullet and try to pull these things out of the rack! Thanks for the help, I wish there was a better way.
Diego
Brandon Buffin Wed, 03/26/2008 - 06:11
It should be right on the front edge so you shouldn't have to pull it out very far.
Brandon
