Using 2 WLC's (WiSM's) for WLAN
Mar 24th, 2008
We currently have 1 WLC (WiSM) installed in our 6513#1 core switch and will soon be installing a 2nd WLC (WiSM) for redundancy in our 6513#2 core switch. Has anyone been through this setup? Just curious to see advice and and caveats that one may encounter?
tstanik Fri, 03/28/2008 - 12:35
If you could show the network diagram it would be more appropriate. However your setup is simple and it will work without any issues.
Scott Fella Fri, 03/28/2008 - 17:21
That setup will be fine. The only caveats are with what ever code you end up using. 4.1.185 has been the most stable code I have setup on the WiSM's. There are other out here who have implemented the newer 5 code. Just search some of the threads for their opinion.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
