CallManager 4.13 and Windows
Answered Question
Mar 24th, 2008
It's been a while since I've had to deal with any of this...
Can CallManger 4.13, running in Win2K, be put in a Windows domain? If so, any gotchas I need to watch out for?
Thanks.
Correct Answer by Jaime Valencia about 9 years 4 months ago
if you put the server in a domain the users will be subject to all the domain policies which can affect them, also in case there is TAC troubleshooting they can ask you to take the server out of the domain if necessary
The recommendation is to keep the server only on a workgroup but if there's a real need to join a domain you may do it
javalenc
if this helps, please rate
Overall Rating: 4.5 (2 ratings)
Mike Reilly Mon, 03/24/2008 - 19:17
Yes, it can be put into a domain but be aware that the first step to any patch or update is to remove it from the domain.
Correct Answer
Jaime Valencia Mon, 03/24/2008 - 19:34
  • Cisco Employee,
  • Hall of Fame,
    2011
javalenc
