Help with Catalyst 2900 XL switch
Mar 24th, 2008
Recently I started revision for my MCSA and decided that I would also put together a test rig to practice on, so I have baught a cabinet and then used some old bits and managed to get 3 servers together.
I decided that since I eventually want to do the CCNA exam that I would use a Cisco switch to help get used to Cisco range, so I ended up buying a second hand Catalyst 2900 XL switch.
I have recieved the switch however I want to be able to try and configure it, if not now at least in the future. However I do not have the username and password, unfortunatly they weren't blank.
I have tried using the password recovery process, however I get so far and then it stops on the following:
Switch#copy flash:config.text system:running-config
Destination filename [running-config]?
1741 bytes copied in 3.172 secs (580 bytes/sec)
Switch#
00:03:16: %SYS-5-CONFIG: Configured from by
and if I press enter it just returns to a Switch# prompt, instead of showing Sw1# as in the documentation. I have also tried the process to reset the switch back to factory settings, but the switch doesn't seem to recognise the "erase startup-config" or "write erase" commands.
Would it be worth going on to IOS 12.x as it is cutrrently on 12.1, would that also mean that there would be default usernames and password.
I would be greatfull for any help and also very keen to learn about Cisco products.
Guy
guy.kramer Tue, 03/25/2008 - 01:18
thanks for the link, however as I said above when I get to step 12 I use the command to copy the config.text to the running config (example below)
But when the command has finished it doesn't return a sw1# to carry on with the steps????
Hi Guy
It does not have to show "SW1". In the document you are using for password recovery "SW1" refers to the host name which is configured on the switch initially.
So when you run the command "copy flash:config.text system:running-config" and you see the output "xxx bytes copied in xxx seconds" this shows that the command was successful. The switch prompt shown will now be what was configured on the switch when you bought it. This most probably will not be SW1. From the output posted in your original post, it appears that your switch was not given a name by the previous owner and was left with the default name "Switch" which is why the prompt does not change.
You can safely finish the procedure. You can give the switch a hostname if you like. Once you see the "#" sign you are privileged exec mode. So from here do the following,
#conf t
(config)#hostname
(config)#exit //Here the switch will show the name you have just given it
#wr mem
Now the prompt should show what ever name you gave the switch.
Best Regards,
Michael
southminder Tue, 04/08/2008 - 23:14
Hi, I am having a similar problem, only I can successfully "reload the configuration file" in step 12 and reach step 13.
But once I type in "configure terminal" it tells me this:
"Command authorization failed."
So it won't let me into configuration mode to actually change the password and I have no clue why? So basically at this point my switch is useless to me... Any ideas?
guy.kramer Tue, 03/25/2008 - 14:27
Hi guys,
Thanks for the advise, it worked a treat. I have two questions left now : )
Question 1: Now I have changed the passwords, but I still don't know what the username is? and ut is asking me for it.
Question 2: What does each of the do or control access to which functions?
Hieu Cao Tue, 03/25/2008 - 17:03
While in the privilege mode, you can create your own username with privilege 15.
config t
username guy priviledge 15 password xxxxxxx
You can remove the old username or simply change its password using the format shown above.
Not sure if I understand your question #2. Can you clarify on this..
HTH,
hieu
guy.kramer Wed, 04/02/2008 - 10:59
Hi Hieu,
thanks for the advise, I have tried what you said but I get the following error:
DR_2924_SWITCH#username guy priviledge 15 password test
% Invalid input detected at '^' marker.
Don;t know what I am doing wrong???
Hieu Cao Fri, 04/04/2008 - 10:27
Guy,
You need to get into the priviledge mode first before creating the local user account.
DR-2924_SWITCH#config t
DR-2924_SWITC(config)#username guy priviledge 15 password test
HTH,
hieu
guy.kramer Tue, 04/08/2008 - 15:12
Hi Hieu.
please can you confirm how I get in to priviledge mode, to check that I am doing it right.
Cheers
Hi Guy
Good to hear you got it sorted. Now to your questions.
Answer 1: Run the command "show run" and check for a line "username password " also look towards the end of the configuration, under "line vty 0 15" for the line "login local"
If you run the "show run" command and post the output here we will have a look and see if we can see anything.
Answer 2: I not sure I understand your question. Is it possible that you left out a word after "What does each of the ???????? do"
Best Regards,
Michael
guy.kramer Wed, 03/26/2008 - 01:25
Hi Michael,
I am at work at the minute so when I get home I will try your advise to users on the switch.
I was wondering what the following passwords are for, and what functions that they control?
secret password
enable password
vty password
console password
shrikar.dange Wed, 03/26/2008 - 01:38
Secret password enables the encryption to be used on the password.So the password will be displayed as the encrypted instead of clear text hence added security.
Console password is used when you try to access the device through console.If you do not provide the correct password then you will not access to the device.
Vty password is used for telnet connection.If you do not specify the VTY password you can not telnet to the device.
Enable passwod is used when you get the access of the device (eighther by console or by telnet)you will be in user mode at start.In this mode you have very limited access so that you can not damage the configuration or device.If now you want to go to priviledged mode and you have configure enable password then you need to provide this password to go in to the previleged mode.Again added security.
HTH,
regards,
shri :)
Hi Guy
Shrikar has provided the answer to question 2, however I would just add that the enable secret supersedes the enable password.
So if you had an enable password of "cisco" and an enable secret password of "ccna", when you connected to the switch and type "enable" it is the enable secret password that will required to enter privilege exec mode, NOT the enable password.
Best Regards,
Michael
guy.kramer Wed, 04/02/2008 - 10:52
Hi Michael,
I managed to change the name of the switch which is good. But it is not showing the any users when I run the "show run" command, please see below:
DR_2924_SWITCH#show run
Building configuration...
Current configuration:
version 12.0
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname DR_2924_SWITCH
ip subnet-zero
interface FastEthernet0/1
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface VLAN1
no ip directed-broadcast
no ip route-cache
line con 0
transport input none
stopbits 1
line vty 5 15
end
Thanks for the help
Hieu Cao Fri, 04/04/2008 - 10:30
You need to get into the priviledge mode first before you can create a local user.
router#config t
router(config)#username .... ...
hieu
